JuanEs
Oct 10, 2020Aspirant
Is the new Orbi cable modem able to substitute the AT&T modem?
The Orbi Facebook ad of the cable-modem Orbi 6 Says it is compatible with AT&T. However, the webpage and box don’t have AT&T as compatible. What is the true? I know I can connect Orbi to the AT&T mode...
- Oct 10, 2020
It depends on exactly what your service. is.
The LBR20 is an LTE cellular modem. It works with at&t cellular network.
If you're on att fiber, the other modems aren't compabile with att as a modem. The non-model version can work in router mode though.
Oct 10, 2020Guru - Experienced User
