Ricmelendez08's avatar
Oct 13, 2022
Is the Nighthawk cm2050v modem compatible with Orbi RBR50 router and 3 satellites?
I’m upgrading my current Nighthawk 1100 that I use with the Orbi RBR50 router and 3 satellites (1 the outdoor extender). Could I go up to the Nighthawk CM2050v to use with the existent Orbi mesh menti...
  • CrimpOn's avatar
    Oct 13, 2022
    The Orbi RBR50 WAN port maxes out at 1GB/s.  The CM1100 modem is already capable of that speed and higher.  There will be no gain from:
    • Purchasing a higher speed modem, or
    • Contracting with Xfinity for more than 1GB/s speed.
    Sorry.  The investment to go beyond 1GB is much more than $200.
