tlf_mb
Apr 12, 2024Aspirant
Is the Orbi Satellites compatible with Nighthawk RAX52.v2?
We have a 2100 sqft home fully prewire and I bought a Nighthawk AX6 router. I want to keep the same SSID . Can I hook up the Orbi Satellites to my Nighthawk router via ethernet port, without hookin...
- Apr 12, 2024
Well as long as your not using same channels betrween the RAX and your perspective AP, then should work ok.
Apr 12, 2024Guru - Experienced User
No. Orbi satellites only connect to there perspective model Orbi router. Don't connect to non Orbi systems.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
