tlf_mb
Apr 12, 2024Aspirant
Is the Orbi Satellites compatible with Nighthawk RAX52.v2?
We have a 2100 sqft home fully prewire and I bought a Nighthawk AX6 router. I want to keep the same SSID . Can I hook up the Orbi Satellites to my Nighthawk router via ethernet port, without hookin...
- Apr 12, 2024
Well as long as your not using same channels betrween the RAX and your perspective AP, then should work ok.
CrimpOn
Apr 12, 2024Guru - Experienced User
tlf_mb wrote:
We have a 2100 sq.ft. home fully prewire and I bought a Nighthawk AX6 router. I want to keep the same SSID .
AX6 is a marketing term describing more than one Nighthawk router. It would be helpful to know the actual model number of this router. When replacing one WiFi router with another, the common practice is to configure the new router with exactly the same WiFi credentials (SSID/password) as the one being replaced. This allows every device in the house to connect automatically to the new router and also allows the user to "go back" to the old router by simply exchanging the hardware.
It also would be useful to understand the reasoning behind the purchase. i.e. what prompted purchasing a stand-alone WiFi router to replace a mesh system of three access points.
With that Orbi Pro system now officially "End of Life", there may be more Netgear customers considering "what to do?"
- FURRYe38Apr 12, 2024Guru - Experienced User
The subject line has the model # of the router there asking if the Orbi satellites will not connect too.
- tlf_mbApr 12, 2024Aspirant
Model: RAX54v2
AX5400 Wifi6 Router.
It's a Nighthawk AX6 wifi router and I like want to add an Orbi satellite without a mesh router. Will it work? Thank you for your help!
- CrimpOnApr 12, 2024Guru - Experienced User
Sorry I did not read the original post more carefully. As FURRYe38 mentioned, Orbi satellites connect only to Orbi routers and there are restrictions on which routers each satellite is compatible with.
Answer: "no".
Should I try an extender and any recommendation? I have not heard any good reviews; mesh system seems to work better, but do not like an additional router. Thank you for your help!
The Nighthawk supposes to cover 2500 sqft (we have 2100 with 3 levels). Our 3rd floor has poor wifi coverage. My TV is using ethernet connection, and we have ethernet connection in every rooms. Thank you for your help!
I would recommend you take a look at NGs EAX series of wifi extenders. I would presume for that size of home, just one EAX series unit will help there.
