tlf_mb
Apr 12, 2024Aspirant
Is the Orbi Satellites compatible with Nighthawk RAX52.v2?
We have a 2100 sqft home fully prewire and I bought a Nighthawk AX6 router. I want to keep the same SSID . Can I hook up the Orbi Satellites to my Nighthawk router via ethernet port, without hookin...
- Apr 12, 2024
Well as long as your not using same channels betrween the RAX and your perspective AP, then should work ok.
Apr 12, 2024Guru - Experienced User
The subject line has the model # of the router there asking if the Orbi satellites will not connect too.
CrimpOn
Great start for my morning! Thanks.
- FURRYe38Apr 12, 2024Guru - Experienced User
Did you not get some coffee Sir? Hehe. Good morning.
- CrimpOnApr 12, 2024Guru - Experienced User
The original RAX54S does not seem to be a "step up" from the Orbi Pro system. Alas, attempts to open the support page for RAX54Sv2 result in "404 - page not found".
