ChrizK's avatar
ChrizK
Tutor
Oct 04, 2021
Is there a Firewall blocking my other network?
Hi,   Firstly, I apologies if my network terminology is incorrect. I switched broadband provider in the UK.  My old router DHCP provided 192.168.1 addresses, the new cannot be re-configured, and o...
  • FURRYe38's avatar
    You can try #2 first and see if this helps, if not, try #3 on Orbi.
