rampi
Jun 09, 2020Guide
Is there a way to force a device to connect to the satellite / router
I have the RBK50 System - RBR50 router + RBS50 satellite. (running v2.5.1.16) Router is placed upstairs Satellite is placed in the ground floor in the hall. I have a TV and Bose soundbar in the ...
- Jun 10, 2020
Not seen on Orbi AX.
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
Jun 10, 2020Guru - Experienced User
- rampiJun 11, 2020Guide
Thanks for this input, I will try this out and update.
Rest of the settings like beamforming, MIMO and WMM are already enabled.
- FURRYe38Jun 11, 2020Guru - Experienced User
Be sure the distance between RBR and RBS is 30 feet to start.
- rampiJun 24, 2020Guide
Wanted to update here that by turning down the transmission power control of 2.4GHz down to 50% makes a difference.
The TV in the hall sometimes connects to a far away satellite on 2.4Ghz, but when that happens, if I reset the wireless connection on the TV, it connects back to the nearest satellite on 5GHz and sticks to it.
Much better, thanks.
