RidaHAKIM
Oct 16, 2019Aspirant
Is there a way to get the VPN to connect with the primary (not guest) network? New Version
I Open a new discussion since the one opened by Stev3D and concerning the same issue has been closed/solved by error. I have a home/primary wifi network on my Orbi set to 192.168.1.x My Orbi is ...
CrimpOn
Oct 16, 2019Guru - Experienced User
(I have no Hue lights, so please bear with me)
Are you using the Bluetooth or the Bridge system?
RidaHAKIM
CrimpOn wrote:(I have no Hue lights, so please bear with me)
I'm using Philips Hue Bridge v2, the one compatible with Apple HomeKit.
- CrimpOnOct 16, 2019Guru - Experienced User
Thanks. Another question: Does the Apple Home app function when you are not "at home", for example at an airport or when connected to WiFi at some other location? (We Android people are blissfully ignorant about how "Apple Stuff" works.)
The reason I ask is I have found few limitations using OpenVPN to the Orbi. Just now, I tested by disconnecting my phone from WiFi and opening OpenVPN over LTE. Yes, the IP address I got was 192.168.2.2. However, the way I learned this was by opening a web browser, connecting to 192.168.1.1 (the Orbi) and bringing up the "Attached Devices" display, which clearly showed my IP address and also the fact that my connection was "VPN" (not "Wired" or "WiFi").
I then pinged devices on my regular subnet (printers, computers, etc.) and they all responded.
I then connected to a couple of Raspberry Pi units using SSH. The tiny characters on the phone screen were frustrating, but I was able to run commands on the Pi's just fine.
So, web browsing, ping, and SSH work to devices on the 192.168.1.x subnet.
What did NOT work, however, was any program that detected I was not on WiFi. I asked Fing, to scan my network, and it refused to run at all. I yelled, "It doesn't matter, dummy, I'm on a VPN." Alas, no. No WiFi, no deal.
So, what does Apple Home do when you are not on WiFi?
- RidaHAKIMOct 19, 2019Aspirant
Hi CrimpOn
CrimpOn wrote:Thanks. Another question: Does the Apple Home app function when you are not "at home", for example at an airport or when connected to WiFi at some other location? (We Android people are blissfully ignorant about how "Apple Stuff" works.)
Never tried it.
Exactly same as me. I can access Orbi through web browser. That' all I can do.
Impossible to ping other thing than the Orbi. Nothing else answer the ping.
Maybe that's the way Apple Home Kit : no WiFi no deal. Or maybe it's the subnet : not the same subnet, no deal. Impossible to know. Anyway thanks for your help.
