Stev3D
Jul 06, 2018Luminary
Is there a way to get the VPN to connect with the primary (not guest) network?
I find the built-in VPN to be very useful for personal network security when on shared/public networks -- and when traveling internationally (I appear to be home, which is what I want). However, I'd...
- Jul 14, 2018
You are the first person to report that Orbi's guest network is on a separate subnet from the main network. See post #1 and many other posts in the below thread.
I switched my Orbi to router mode just to test, and confirmed that for my Orbi the guest network is on the same subnet as the main network. In my case the Orbi is at 192.168.1.1 and the guest gets an IP of 192.168.1.5, which is on the same subnet. This is what I mean by "Orbi does not have a separate guest network." Yes, there is a separate SSID, but all clients are on the same subnet.
Furthermore, there is no setting in Orbi that I see that allows one to choose a different subnet for the guest network.
So, either you are using a different router than Orbi, you are using some new unreleased firmware, or there is something misconfigured with your network.
Where is the Orbi setup page where you can set a different IP for the guest network?
What firmware version are you running?
Jul 08, 2018Guru - Experienced User
I was tagging DarrenM for his review and comment and help.
The information you see for my signature is the items I currently have and test with. The top line is actually deployed in my home. The second line is items I have at my disposal for use.
Hopefully Darren will review this by tomorrow...
Good Luck.
