Stev3D
Jul 06, 2018Luminary
Is there a way to get the VPN to connect with the primary (not guest) network?
I find the built-in VPN to be very useful for personal network security when on shared/public networks -- and when traveling internationally (I appear to be home, which is what I want). However, I'd...
- Jul 14, 2018
You are the first person to report that Orbi's guest network is on a separate subnet from the main network. See post #1 and many other posts in the below thread.
I switched my Orbi to router mode just to test, and confirmed that for my Orbi the guest network is on the same subnet as the main network. In my case the Orbi is at 192.168.1.1 and the guest gets an IP of 192.168.1.5, which is on the same subnet. This is what I mean by "Orbi does not have a separate guest network." Yes, there is a separate SSID, but all clients are on the same subnet.
Furthermore, there is no setting in Orbi that I see that allows one to choose a different subnet for the guest network.
So, either you are using a different router than Orbi, you are using some new unreleased firmware, or there is something misconfigured with your network.
Where is the Orbi setup page where you can set a different IP for the guest network?
What firmware version are you running?
st_shaw
Jul 14, 2018Master
Stev3D wrote:
I find the built-in VPN to be very useful for personal network security when on shared/public networks -- and when traveling internationally (I appear to be home, which is what I want). However, I'd like to be able to access resources on my home (primary) network. However, by default (probably for understandable security reasons) the VPN seems to only attach to the guest network I set up for visitors. So I'm unable to access any of my internal home network services.
The question: Is there a way to configure the Orbi to put the VPN on the primary network?
I haven't used Orbi's VPN yet, because I use Orbi in AP mode, but it's not supposed to work that way. Also, Orbi does not have a separate guest network, so what are you seeing that makes you believe the VPN is attaching to a guest network?
Did you read the manul sections regarding VPN?
https://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
There are settings for allowing access to the home network and the Internet over the VPN. Check those.
Also note the comment on page 119 and make sure this isn't the issue:
"For the VPN tunnel to work, the local LAN IP address of the remote router must use a different LAN IP scheme from that of the local LAN where your VPN client computer is connected. If both networks use the same LAN IP scheme, when the VPN tunnel is established, you cannot access your home router or your home network with the OpenVPN software."
Jeremyinsf
Jul 14, 2018Apprentice
A more technical way to respond is to say that the VPN subnet assigned / used for VPN clients is a different one than the local LAN, and there doesn't seem to be any way to assign/control/change any of those settings. And when on a VPN subnet, it doesn't seem to openly communicate (route) to the local LAN subnet so you can access resources directly. It appears to isolate them no matter what you set per instructions on page 119.
So my example - when on VPN I can't ping any resources on the regular Orbi LAN, and I can't access my DVR from 'inside' like I would hope to.
(Related but unrelated - this problem would sort of be the opposite of where there is a checkbox for allowing Guest wireless clients to see the regular lan and vice versa - there is a checkbox for that, but it doesn't work, and that is well documented on this forum)
- st_shawJul 14, 2018Master
Having VPN clients on a different subnet is normal, and shouldn’t be a problem.
However, note that Windows firewall by default will block any communications with a computer on a different subnet. So you won’t be able to ping or connect to any Windows machine on your home LAN unless you add firewall rules to allow it, or disable the firewall. You might need to do the same on the VPN client computer, depending on how it’s setup.
- JeremyinsfJul 14, 2018ApprenticeYeah, that is not the issue here. At least for me.
- Stev3DJul 14, 2018Luminary
@st_shaw, thank you for responding.
I don’t understand what you mean by “Orbi does not have a separate guest network?” I know that here is an entire section on setting one up in the manual you linked (in Chapter 6). I’ve established a guest network (different IP address, different SSID, different WPA2 password) so visiting friends can use my ISP but do not have access to my internal services.
The answer to your question “So what are you seeing that makes you believe the VPN is attaching to a guest network?” is that the apparent VPN LAN subnet address matches that of my guest network — which differs from that of my primary network (and the local LAN I was tunneling in from).
I’ve been through the the manual (several times) — which is fairly thin on VPN technical details (spends a lot of time on elementary step-by-step for client setup). I use a fairly non-standard number for the third octet on my LANs (and the primary network and the guest networks differ by one), and not the default. The probability of a collision is small (one out of 254 for a Class C private network, and zero if its Class A or B). I know for sure that the “the LAN IP scheme” isn’t the issue.
Since my guest network can’t route to my primary network (by design), having the VPN tunnel terminate on the guest network prevents me from accessing services. Being on separate subnet is a non-problem when they are routed, but the point of a guest network is to keep untrusted devices away from the “inner sanctum,” so that isolation (not routing between them) is intentional. If the VPN setup in the Orbi gave us a choice of having the tunnel land in one or the other, I’d be able to do what I want.
Aside: I’m not using any Windows devices, so Windows firewall is not part of the equation.
@Jeremyinsf, I quite agree with your assessment of the situation.
Thanks to all who responded. It would be great if someone form Netgear weighed in.
