bottomsup
May 05, 2020Guide
Is there a way to view data usage per device?
On Orbi RBK50 Thanks
CrimpOn
May 05, 2020Guru - Experienced User
bottomsup wrote:
On Orbi RBK50
No, there is not. One user was so determined to find per device usage that he purchased a different router and installed 3rd party software on it for this purpose. If you have $150 and want to invest the time, that is the only solution I have seen.
May 06, 2020Guru - Experienced User
its the top requested feature on the idea's exchange for home
https://community.netgear.com/t5/Idea-Exchange-For-Home/Bandwidth-monitoring-by-device/idi-p/1627368
