wolfereeno
Mar 10, 2020Apprentice
Is there an upgrade path from Wifi 5 to 6 for an RBK50 owner?
I have an RBK50, so a RBR50 router and RBS50 satellite. I need a 3rd satellite for better coverage upstairs. First, are there any plans to upgrade the RBR50's to WIFI 6 via firmware upgrades...
Mar 10, 2020Guru - Experienced User
wolfereeno wrote:I have an RBK50, so a RBR50 router and RBS50 satellite. I need a 3rd satellite for better coverage upstairs.
First, are there any plans to upgrade the RBR50's to WIFI 6 via firmware upgrades?
The RBK50 is not HW compatible or has any HW support for WiFi 6. Orbi AX systems has already come out and is WiFi 6 Supporting:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Secondly, is there any planned compatibility between the newer wifi 6 orbi's and the older ones?
NG is supposed to made the RBS50 satellites compatible. Not sure when though.
Wondering if I just wait for the prices to come down on another RBS50 and skip Wifi 6 altogether. This is just for home and home office use. If the 50 series is working well for you, keep it. Until you get more devices with AX wifi, not a real need to upgrade until then.
- wolfereenoMar 10, 2020Apprentice
OK thanks guys.
I'm sure I need the additional coverage. I have kind of an unusual multi floor apartment.
The RBS50 seems to cost almost as much as the whole 2 unit RBK50 kit so I've been trying to just wait for a sale. I could get the two radio version RBS20 but I'd rather get 50 if the prices drop.
- FURRYe38Mar 10, 2020Guru - Experienced User
Hope you can find something that works for you.
- GMoGoody8Aug 17, 2020Luminary
I was in the same boat and it appears the RBS50 is discontinued. All I can find are refurbished and used units which is another reason prices are so high.
I ended up pulling a trigger on a RBS50Y and going to put it in my garage or on my deck. Where originally I was going to put the RBS50 on the other side of the wall inside. This though forces me to wireless backhaul since the RBS50Y doesn't have Ethernet ports.
I didn't want to yet buy a completely new Orbi system/kit as my RBR50 is only 18 months old.
