ragnar21
Aug 02, 2022Follower
Is there any custom firmware for the Orbi RBR20?
As per topic. I'm struggling very hard to fix up my network after a change to the national infrastructure borked my Netgear dm200's compatibility as a modem. Now I've got the dm200 working again some...
Aug 02, 2022Guru - Experienced User
You set your orbi in access point mode?
And you're sure the DM200's custom firmware isn't whats the issue?
Because if the orbi worked fine before you had the custom firmware on the dm200, that's where I'd be checking
CrimpOn
DM200 is a modem only. The Orbi must be in router mode, not access point mode
https://www.netgear.com/images/pdf/DM200_DS_01Apr16.pdf
- plemansAug 02, 2022Guru - Experienced User
CrimpOn no. The DM200 has router/dhcp options. And they're enabled by default.
I've used one before. Just need to look at the manual a little closer to find it.
I wasn't aware there was decent 3rd party firmware for it. That's what I'd be questioning if it was actual in router mode with the 3rd party firmware on it.
- CrimpOnAug 02, 2022Guru - Experienced User
Indeed. Page 69: https://www.downloads.netgear.com/files/GDC/DM200/DM200_UM_EN.pdf
I guess back in 2017 Netgear felt no need to point this out in the Product Data Sheet. My Bad.
