samsamsamsam
May 30, 2017Guide
Is there any way to disable the auto firmware update? Issues since the latest V1.10.1.2 update
Ever since the last update, I've had extremely slow connection speeds through the satellite with my iOS devices. To illustrate, I just ran a test where the results were 8.33 Mbps D, 1.52 Mbps U and e...
MachineLearner
May 31, 2017Apprentice
Not sure how to disable auto update, but you could check the IPv6 setting and see if the firmware update changed it. Mine came with IPv6 "disabled" by default. I enabled it with one of the IPv6 setting options, and initially noticed a performance hit. That could have been coincidental, as our ISP has had a few coverage issues in our area recently due to some network upgrades they are doing. You could experiment with that setting.
samsamsamsam
May 31, 2017Guide
I appreciate the help. IPv6 was set to disabled and I changed it to Auto Config and Auto Detect, none of it had any effect.
