FWIW
May 30, 2019Aspirant
Is there such a thing as being too close to the router?
My router is in a closet in the center of the house about 6' off the floor. It is about 20 feet from the head of the bed in the master bedroom. The satellite is at the other end of the house about ...
- Nov 19, 2019
I finally switched from the Orbi to an R8000. I use the Orbi in my pole barn. All my problems went away.
ekhalil
May 30, 2019Master
FWIW wrote:.....
Is there such a thing as being too close?
I don't think the issues you're seeing are a result of being close to the Router. If you see frequent disconnections then you must have other issues.
Please provide more information about your setup so we might be able to help you.
- ssgtweaselNov 18, 2019GuideIs connecting satellites via Ethernet better than Wi-Fi? I would suspect so
I have 2 satellites and router and all are connected via cat6. 2 story townhome
I’m trying to achieve best 5ghz coverage as possible
Router and 1 satellite are same floor with max distance
2nd is on fist floor almost directly below
I’m concerned each item is too close to each other- CrimpOnNov 18, 2019Guru - Experienced User
Do these connection problems happen when a device 'moves' around the house?
On the Orbi web interface, the Advanced Tab->Advanced Setup->Wireless Settings, toward the bottom, are the three boxes checked
- Enable Beamforming
- Enable MU-MIMO
- Enable Fast Roaming
- ekhalilNov 18, 2019Master
........Wired backhaul is -for sure- more robust than wireless, but you should get better backhaul throughput (up to 1.7 Gbps) on wireless if you have an RBK50.
ssgtweasel wrote:
I’m concerned each item is too close to each otherDo you see throughput, roaming or wifi drop issues?
- FWIWNov 19, 2019Aspirant
