FWIW
May 30, 2019Aspirant
Is there such a thing as being too close to the router?
My router is in a closet in the center of the house about 6' off the floor. It is about 20 feet from the head of the bed in the master bedroom. The satellite is at the other end of the house about ...
- Nov 19, 2019
I finally switched from the Orbi to an R8000. I use the Orbi in my pole barn. All my problems went away.
ekhalil
Nov 18, 2019Master
ssgtweasel wrote:
Is connecting satellites via Ethernet better than Wi-Fi? I would suspect so
Wired backhaul is -for sure- more robust than wireless, but you should get better backhaul throughput (up to 1.7 Gbps) on wireless if you have an RBK50.
ssgtweasel wrote:
I’m concerned each item is too close to each other
Do you see throughput, roaming or wifi drop issues?
FWIW
Nov 19, 2019Aspirant
