dpdurst's avatar
dpdurst
Luminary
May 25, 2017
Is this correct?
I have noticed after upgrading to 1.10.1.2 that the 2.4ghz connection shows not connected as below? I have devices showing up on Channel 4, but it seems that its only showing the backhaul connection? The router shows all is fine. Maybe I've just never noticed before?orbi sat.jpg
  • The answer is no, its not. Broke the connection, reflashed with previous version and then back to 1.10 and resync and now its showing both connections
1 Reply
