boombox
Jan 12, 2020Aspirant
Is this setup possible with a RBK50
Hi there, Thinking about purchasing the RBK50. Before i do, can somebody confirm if the setup i'm thinking about will work? Please see my attachment for a diagram supporting my question: ...
- Jan 14, 2020
You can connect any kind of switch to the back of Orbi. For managed switches, be sure ALL IGMP protocols are disabled. Some switches that have "green ethernet" features are also not recommended with Orbi.
Jan 12, 2020Guru - Experienced User
I've had mine done in a similar setup. I tried both:
modem----rbr50-----managed switch-------satellites and other devices
modem----rbr50----sats
managed switch
Both worked when i used them like that. the rbr50 units have 3x ethernet ports on the back
Did that answer your question?
