donawalt
Feb 14, 2022Hero - Experienced User
Is this the proper set up strategy?
Hi all, I am slowly moving my RBR/RBS850 setup from having satellites with all wireless backhaul to all wired backhaul. There isn't a ton of info on strategies of where to place satellites that I...
- Feb 14, 2022
its a pretty accurate way of putting it.
I've moved mine around a ton to try to optimize as I've tested running 1 satellite all the way up to 4 satellites. So if you try different locations, you might find one that works better. Just make sure they're at least 30 ft between router/satellites for proper roaming.
Feb 14, 2022Guru - Experienced User
