ldehoyos208
Aug 11, 2019Aspirant
ISP said needed an N router
Due to rural area, I am now using Blazing Hog Internet and was told that I needed to get a N type router. I purchased a Orbi 2200 which I was tod supported N and AC.Does it make a difference and is ...
ldehoyos208
Aug 13, 2019Aspirant
Very slow connectivity. When I signed up for the service I was informed their service was 5 times faster than a mobile hotspot. I attempted to connect to their service and it was so slow that none of my work applications worked.
Aug 13, 2019Guru - Experienced User
What ISP service company are you signed up with?
What wireless devices are you connecting to the Orbi?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
ldehoyos208 wrote:Very slow connectivity. When I signed up for the service I was informed their service was 5 times faster than a mobile hotspot. I attempted to connect to their service and it was so slow that none of my work applications worked.
