Kimreichelt1
Mar 19, 2021Tutor
ISP speeds
I have 1.2gbps service from comcast. Will my RBK753 router handle this speed? What is the max speed it can handle? (I have a CM1200 router)
Yes. It appears that both the CM1200 modem and the RBK750 router support "Link Aggregation" which provides more than gigabit speed between modem and router. Check the User Manuals for modem and router:
https://www.netgear.com/support/product/cm1200.aspx#docs
https://www.downloads.netgear.com/files/GDC/RBK752/RBK752_UM_EN.pdf
search for "Link Aggregation".
Netgear has set up a community forum specifically for the "AX" Orbi products. It is more likely that someone who owns the CM1200 or RBR750 will notice a post in that forum than in this one. The AX forum is here:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
- No, that is not my question.
My question is, what is the maximum speed tier form my ISP that my RBK753 can support.
In other words, I have 1.2gbps service from comcast. Will my equipment support this speed?
