Spike454
Sep 09, 2024Aspirant
Issue connecting netgear orbi rbs50 satellite to rbr50
Hello. I have had the netgear Orbi rbr50 and rbs50 for about 6 years. Has worked great overall. I have 3 rbs50 satellites. I have had some connection issues the past few months, to the point they all ...
Sep 10, 2024Guru - Experienced User
Was FW updated on each RBS first, then the RBR lastly?
Turn OFF all other RBS and try to sync the RBS to the RBR. Try generating a new backhaul pass word found under Advanced Tab/Advanced Settings/Wireless Settings. Factory reset the RBS by pressing the reset button for 15 seconds then release, then when the back LED turns green, unplug the power for 10 seconds then plug back in. Give it 2 minutes then try to sync it to the RBR using the Add Satellite feature on the RBRs web page. Have the RBS in same room as the RBR.
Spike454
Sep 22, 2024Aspirant
Thank you so much for your reply.
The current firmware on the router and satellites is V2.7.4.24. I cannot tell what firmware is on the one satellite that won't connect but I'm assuming the same given they were all updated at the same time a few years ago.
I do not know in what order they were updated. I've always just done it through the cell phone app. It has been multiple years since I updated to this firmware.
I followed the advice as written. The 2 satellites that do connect now consistently connect. With those unplugged I'm still not getting the 3rd to connect when in the same room a few feet away. When I wire it via Cat cable to the router, the led turns blue indicating it is connected, but it does not get recognized by the system as a satellite (in the app or when logged in through orbilogin.com). It will be listed as a wired connected device like in the picture I attached previously. If I try to sync it without the cat cable, it will be magenta suggesting it didn't connect.
My guess is it may just be bricked at this point given its almost 7 years old. If you have any more advice, I am open to it. Thank you very much again for helping
- FURRYe38Sep 22, 2024Guru - Experienced User
Might try a factory reset on the RBR and the one RBS and see if it will auto connect to the RBR when the RBR it at the beginning setup wizard screen in a web browser at 192.168.1.1. Usually the RBS will auto sync about 5 to 10 minutes into to the default SSID name and PW set by during Mfrg.
Lastly would be to try a 30-30-30 reset on the one RBS and see if this can get it to fully reset then reconnect. If this fails then most likely RBS has gone bad. There maybe more advanced ways to see if you can recover it but not sure if you wanna go down that road, would need to open the case up. Maybe able to find used RBS on places like amazon, ebay or shopgoodwill.
Last official FW for the 50 series is here:
