fsa317
Nov 19, 2020Aspirant
Issue keeping a ps4 connection
My setup: I have my RBR40 router hardwired connected in AP mode to my Verizon Fios Router (with gigabit speed). This RBR40is in a back room in my basement. I also have an RBS20 on my second floor ...
Nov 19, 2020Guru - Experienced User
Its not recommended to put wfi if routers in the basement. Concrete and steel will inhibit good wifi signal travel and coverage.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
fsa317
The RBR being inthe basement is the reason the RBS is also hardwired. They are probably about 50 feet apart from each other.
