jdpg2
Apr 06, 2018Apprentice
Issue with 2.1.3.4 in AP mode?
Is anyone else running their Orbi in AP mode? I am having an issue where wireless clients are not getting an IP address assigned to them from DHCP server via the Orbi but hardwired clients are. ...
- Apr 06, 2018
Well some Putty and the internet and i have it sorted out. There clearly is an issue somewhere in the new FW. But after some nvram show, grep, and set i over wrote the wrong DCHP values and i now have Wifi.
I think netgear should give the new FW another look before grandma bricks her wireless because they wont know how to use Putty :D.
jdpg2
You would hope so but i have done 2 resets now with no change.
jdpg2
- FURRYe38Apr 06, 2018Guru - Experienced User
Possible upgrade process issue. How did you upgrade your unit? Auto upgrade or manual?
What specifc browser are you using?
I use manual and have never seen this kind of problem. I believe others have used auto upgrade and it's worked for them in the beta thread...
- jdpg2Apr 06, 2018Apprentice
I have been loading all of the FW updates (publically released and Beta) all via manual updates and most via clean resets. This one is really strange since i just stopped working.
Ya this one is very strange...
Edge and or Chrome... really irrelevant since i have had succes with both.
See bad behaviors before with Chrome. Try this next time please, use IE11 and or FF.
Hope it keeps working now. Glad you got it runing correclty. Hopefully won't happen again.
Enjoy.
- bhenryApr 07, 2018Tutor
To the guy using his Orbi with Comcast and in just AP mode. I am able to use my Orbi setup in just AP mode and all my wireless devices are getting an IP from the Xfinity XB6, gigabit.
I have the Xfinity to a 8 port switch, then port to the Orbi as AP only. Port 2 goes to a wired device in office, port 3 to printer.
I am NOT using wired backplane on orbi. The upstairs satellite and den satellite are both working fine and running the new 2.13.4 firmware and using a wireless backplane.
Upstairs I have a wired port that runs to port 5 on the 8 port switch, that port goes to a switch that distributes wired ethernet to the den TV, den Xbox, AppleTV, and a upstairs tme machine backup drive on wired (old Airport Express with wireless turned off just using as timemachine drive).
So there are 3 switchs in the house in the mix, and IP passes to all fine wired. Are you using a wired backplane in any manner AND have you made sure you don't have a RESERVED IP setup in your comcast router. Your Orbi satellite is going to think its getting DHCP but the Comcast box when using RESERVED IP will always give it the same UP - like a static IP but forced on the device by the router not setup in the Orbi.
- jdpg2Apr 07, 2018Apprentice
my set up is a bit different. My Comcast GB router is in Bridge mode and connected to an Untangle Network appliance. I have it wired to several unmanaged 8 port switches. So DCHP (ip's) are assinged by the Untangle device. The issue i had was the update didnt set the wan DHCP server value to the Untangled IP , it had it set to some unknown default ip address. Once i telneted in and edited it with Putty it worked fine. I have since dont a full rest and restore again and it appears to be working fine. The issue is if someone else has a similar issue i am not sure they would have the IT experience to edit their nvram...
