jdpg2
Apr 06, 2018Apprentice
Issue with 2.1.3.4 in AP mode?
Is anyone else running their Orbi in AP mode? I am having an issue where wireless clients are not getting an IP address assigned to them from DHCP server via the Orbi but hardwired clients are. ...
- Apr 06, 2018
Well some Putty and the internet and i have it sorted out. There clearly is an issue somewhere in the new FW. But after some nvram show, grep, and set i over wrote the wrong DCHP values and i now have Wifi.
I think netgear should give the new FW another look before grandma bricks her wireless because they wont know how to use Putty :D.
Apr 07, 2018Guru - Experienced User
Hopefully this is a corner case issue. Haven't seen this with anyone else with this odd after FW update behavior. Possible issue between this Untangle device as the Orbi as well.
- jdpg2Apr 07, 2018Apprentice
Zero to do with untangle. This was purley an issue with the FW install and reset. I was on a prior version of the FW (was a beta) , so clearly something between them didnt mix. Regardless i hope grandmas Orbi doesnt STB when this gets pushed to them.
