Eld212
Jan 19, 2017Aspirant
Issue with Internet 1 min after Orbi setup
I am using orbi on starhub 1gpbs fibre plan. Recently purchase an orbi, however I am facing Internet issue. Orbi will detect Internet connection for 1 to 2 minutes. There after the connection will ...
- Jan 19, 2017Mean the ip range of my orbi should be the same as my router?
Eld212
How to allocated ip?
Starhub is an Internet service provider via fibre ont. I also have voip service as well. Read that I need to set orbi on AP mode rather than router mode??
Will I lose routing capabilities?
- MarkC1024Jan 19, 2017Luminary
Presuming that your Internet device coming into your residence isn't assigning IP's to clients, you can look at your other router to determine what IP range it's allocating via DHCP. Then have a look at the Orbi under the Advanced Setup tabs / LAN and match that to be the same as your other router.
I think you need to also understand why/who is recommending the Orbi to be run in AP mode.
