Eld212
Jan 19, 2017Aspirant
Issue with Internet 1 min after Orbi setup
I am using orbi on starhub 1gpbs fibre plan. Recently purchase an orbi, however I am facing Internet issue. Orbi will detect Internet connection for 1 to 2 minutes. There after the connection will ...
- Jan 19, 2017Mean the ip range of my orbi should be the same as my router?
Eld212
- MarkC1024Jan 20, 2017Luminary
Not necessarily, but that would help rule out that element as the problem. If the problem is an IP conflict, and it is currently set different than your router, configuring it the same and then taking the router out of the equation could test that line of thinking. Again, it boils down to understanding why the the Orbi is needing to be put in AP mode to function in your setup. You can leave it like it is behind the router, but if you want to understand the "why", it may take some testing.
