Eld212
Jan 19, 2017Aspirant
Issue with Internet 1 min after Orbi setup
I am using orbi on starhub 1gpbs fibre plan. Recently purchase an orbi, however I am facing Internet issue. Orbi will detect Internet connection for 1 to 2 minutes. There after the connection will ...
- Jan 19, 2017Mean the ip range of my orbi should be the same as my router?
st_shaw
Jan 20, 2017Master
Eld212 Did you get it working now?
Is the Orbi in AP mode or router mode?
What did you change to get it working?
Eld212
Jan 20, 2017Aspirant
Still not working
- st_shawJan 20, 2017Master
Ok. I recommend you just set your Orbi to AP mode and enjoy the better WiFi coverage. The benefit of Orbi is increased WiFi coverage, not advanced router features.
The main thing you will lose in AP mode is Orbi's OpenVPN server capability. OpenVPN will be 50X to 100X slower than your fiber connection, though, so it's not a good solution for you anyway.
You should turn off the WiFi radio iin your existing router to avoid interference and make sure the DHCP server in Orbi is disabled. That's about it.
It's impossible to help you configure Orbi properly in router mode without complete details on your existing equipment. It's also not clear there's any good reason to do that! You said you have VOIP. If the router provided by your ISP is setup to support your VOIP, then replacing the router with Orbi could cause problems with your VOIP.
I have my Orbi in AP mode behind an $800 enterprise-grade router and the Orbi works great. The Orbi provides far fewer router features than my existing router and I would never replace my existing router with Orbi. The Orbi WiFi far exceeds the WiFi capability of my existing router though!
- Eld212Jan 20, 2017Aspirant
I found the solution, is not about setting orbi to AP, it did not work. The solution was to set MAC to "use computer MAC" instead of default.
I am just curious, why it works?
