Eld212
Jan 19, 2017Aspirant
Issue with Internet 1 min after Orbi setup
I am using orbi on starhub 1gpbs fibre plan. Recently purchase an orbi, however I am facing Internet issue. Orbi will detect Internet connection for 1 to 2 minutes. There after the connection will ...
- Jan 19, 2017Mean the ip range of my orbi should be the same as my router?
Eld212
Jan 20, 2017Aspirant
I found the solution, is not about setting orbi to AP, it did not work. The solution was to set MAC to "use computer MAC" instead of default.
I am just curious, why it works?
- MarkC1024Jan 21, 2017Luminary
Something to do with your ISP?
If your ISP requires MAC authentification, then select either Use Computer MAC address to disguise the router's MAC address with the computer's own MAC address, or Use This MAC Address and manually type the MAC address for a different computer. The format for the MAC address is XX:XX:XX:XX:XX:XX. This value can be changed if Use Computer MAC Address is selected once a value has already been set in the Use This MAC Address selection.
