bbrener
Oct 12, 2018Aspirant
Issue with ORBI RBK20 Using RDP
My ORBI is set up and seems to be worling fine. Internet Speed 150MBPS and wifi speed almost the same in my house. However, I connect to my office using RDP protocol and this connection is very slow....
bbrener
Oct 13, 2018Aspirant
Not sure what you mean? Use my old router for the wired connections including RDP from my PC and the ORBI as an AP for wireless only?
Oct 13, 2018Guru - Experienced User
Kind of, wire the PC to the Orbi in AP mode thats connected to your old router and see if the problem continues.
- bbrenerOct 13, 2018Aspirant
Does that mean it "passes through" the Orbi and the packets actually handled by the old router? If it all works does that imply the ORBI is causing an issue?
- FURRYe38Oct 13, 2018Guru - Experienced User
Possible. Reason for this test to see...This give NG something to review to see if they can fix...
