rwilliams1
Apr 11, 2019Aspirant
Issue with Orbi RBR50
If you are connecting your Orbi router and satellite together via ethernet, there is no need to have the radio backhaul channel active, yet there is no way to turn this off in the software.
In my c...
Jun 20, 2019Guru - Experienced User
You can easier disable 5Ghz SSID by disabling the 5Ghz SSID Under Advanced Tab/Advanced Settings/Wireless Settings. No need to go thru all the telnet hassle anymore.
