gui83
Jun 30, 2020Follower
Issue with satelite - not connecting, not resetting
Hello, I have a mesh solution with 2RBS20 + modem. Everything has been working perfectly for 12 months - but suddenly one of the satellites stopped working. It shows as "not connected" on the app an...
Jun 30, 2020Guru - Experienced User
Be sure the RBS are using same version of FW as the RBR.
Did the RBS appear on the RBRs web page?
Press the back reset button for 15 seconds then release. Then try to sync the RBS.
