MikeG63
Oct 22, 2019Apprentice
Issues After Upgrade to Firmware v2.5.0.38 with Orbi RBK53
So, I have upgraded successfully to v2.5.0.38 and everything seems to be fine. However I have noticed that in quite a few cases the Device Model, Device Name and Device Type settings I previously...
Oct 22, 2019Guru - Experienced User
I'd love to give you a way to fix it. Problem is I've found that the RAX and the orbi devices connected devices page both have had issues with this. It works in some firmwares and not in others. Its a fairly large frustration. I have noticed that the issues tends to be more prominent if you have >30 devices connected.
- MikeG63Oct 22, 2019Apprentice
Thanks for the prompt reply, yes I agree, it does seem to be very firmware dependent as I didn't notice this issue with the previous release. Also as I have some 35 devices connected your hypothesis would seem correct.
Ho hum, patiently awaits the next firmware upgrade :smileyhappy:
- Retired_MemberOct 22, 2019
MikeG63 wrote:Ho hum, patiently awaits the next firmware upgrade :smileyhappy:
or...you could try to revert back the FW and NOT do manual updates in the future.
If it was not such a trivial 'bug' which is more of an irritation / inconvenience I would agree. I get it that software is not an exact science, but it does seems a very basic debugging test that has been missed!
