MikeG63
Oct 22, 2019Apprentice
Issues After Upgrade to Firmware v2.5.0.38 with Orbi RBK53
So, I have upgraded successfully to v2.5.0.38 and everything seems to be fine. However I have noticed that in quite a few cases the Device Model, Device Name and Device Type settings I previously...
MikeG63
Thanks for the prompt reply, yes I agree, it does seem to be very firmware dependent as I didn't notice this issue with the previous release. Also as I have some 35 devices connected your hypothesis would seem correct.
Ho hum, patiently awaits the next firmware upgrade :smileyhappy:
Retired_Member
Oct 22, 2019
or...you could try to revert back the FW and NOT do manual updates in the future.
- MikeG63Oct 22, 2019Apprentice
If it was not such a trivial 'bug' which is more of an irritation / inconvenience I would agree. I get it that software is not an exact science, but it does seems a very basic debugging test that has been missed!
- Retired_MemberOct 22, 2019
MikeG63 wrote:If it was not such a trivial 'bug' which is more of an irritation / inconvenience I would agree. I get it that software is not an exact science, but it does seems a very basic debugging test that has been missed!
it could possible be that NG considers some users to be a part of the debugging process. Ask those who live on the edge.
