cool2562
Oct 04, 2018Star
Issues after upgrading firmware
All my WIFI devices are connecting to the router instead of the closer sattelites after new firmware update.
Retired_Member
Oct 05, 2018
Are the Sats even functioning? Blue light, magenta light, no light..??
- cool2562Oct 05, 2018StarNo light but all are accessible via network map and logging into the main router.
- Retired_MemberOct 05, 2018
cool2562 wrote:
No light but all are accessible via network map and logging into the main router.Since you're dealing with a FW update(?)....you may want to unplug the device(s) (reset) that only connect to the router and then plug them back in.
Perhaps during the upgrade as things came back online, the router was first online and the devices just followed suit.
or..just shut the whole network down and reboot the modem and router. What is your setup...modem then the Orbi router???
- cool2562Oct 05, 2018StarModem then Orbi router. I had no issues before the firmware update. When I get home I will manually upgrade the firmware and overwrite it as suggested.
