cool2562
Oct 04, 2018Star
Issues after upgrading firmware
All my WIFI devices are connecting to the router instead of the closer sattelites after new firmware update.
Jcmaster
Oct 08, 2018Aspirant
i have the same problems, and i found that although it show to connect the RBR20 , but actually is connect to the closer sattelites(becoz i just shut down the sattelites and find that the my phone wifi signal disappear.) i guess is the bug of showing the wrong sattelites.
*i try factory reset few times
- FURRYe38Oct 08, 2018Guru - Experienced User
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually. Hoping NG support can have a look at this. So try this out as well.
Disable MIMO, Fast Roaming, IPv6 as well.
