Erimcconville's avatar
Jun 03, 2019
Issues connecting HEOS systme with RBR50
Hello, I've been having issues keeping my HEOS system on my Orbi network.  I called HEOS and they recommended upgrading the router.  My question is this... if I upgrade the router to AC2200 will the ...
  • FURRYe38's avatar
    N600 is 300Mbps UP and Down connection rate between older generation routers and client devices on 2.4Ghz and 5Ghz N mode. Todays newer generation routers are 600Mpbs on 2.4Ghz N mode and 866-1300Mbps on 5Ghz AC mode. Not sure who at HEOS your talking to however whom ever said this may not be giving you accurate information or fully understand todays wifi routers. :smileyfrustrated:
    The Orbi can fully support this music system I believe.
