Erimcconville
Jun 03, 2019Aspirant
Issues connecting HEOS systme with RBR50
Hello, I've been having issues keeping my HEOS system on my Orbi network. I called HEOS and they recommended upgrading the router. My question is this... if I upgrade the router to AC2200 will the ...
- Jun 03, 2019
N600 is 300Mbps UP and Down connection rate between older generation routers and client devices on 2.4Ghz and 5Ghz N mode. Todays newer generation routers are 600Mpbs on 2.4Ghz N mode and 866-1300Mbps on 5Ghz AC mode. Not sure who at HEOS your talking to however whom ever said this may not be giving you accurate information or fully understand todays wifi routers. :smileyfrustrated:
The Orbi can fully support this music system I believe.
Erimcconville
When I talked with HEOS support they said the router needed to be at least N600. I am not sure what that means. Is the RBR50 at least N600?
Jun 03, 2019Guru - Experienced User
- ErimcconvilleJun 03, 2019Aspirant
Thank you. The system will connect then drop within a few minutes.
- FURRYe38Jun 03, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.Try some of these suggestions.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).I presume if this is the only devices that exhibits issues, then this maybe a HEOS problem...Something HEOS will need to review.
