f00bz
Mar 14, 2020Aspirant
Issues with blocked websites
I’ve been having issues where my orbi has been blocking websites via social media links and also updates and installations from my Xbox. Any help how I resolve this?
Mar 14, 2020Guru - Experienced User
f00bz
I’m really bad with technology stuff. Firmware is V2.5.1.8. My Orbi is a RBR50 that is run by Verizon FiOs my Downlod is 941. Upload 868.
I tried installing my ring system via the Orbi and I was not getting any notifications. As soon as I switched to my Verizon wireless it worked. Same with the Xbox updates for apps like Disney+
- FURRYe38Mar 14, 2020Guru - Experienced User
What is the model# of the ISP modem the NG router is connected too? Sounds like a built in router and wifi here. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI recommend trying option #3...
I tried installing my ring system via the Orbi and I was not getting any notifications. As soon as I switched to my Verizon wireless it worked. Same with the Xbox updates for apps like Disney+ - Retired_MemberMar 14, 2020
I tried installing my ring system via the Orbi and I was not getting any notifications. As soon as I switched to my Verizon wireless it worked. Same with the Xbox updates for apps like Disney+get rid of V2.5.1.8.
- FURRYe38Mar 15, 2020Guru - Experienced User
Any progress on this?
I tried installing my ring system via the Orbi and I was not getting any notifications. As soon as I switched to my Verizon wireless it worked. Same with the Xbox updates for apps like Disney+- Retired_MemberMar 15, 2020
:smileysad:
