dbadrak
Jan 14, 2021Aspirant
Issues with firmware on RBS20 and RBR20
(I posted this in the general purpose forum and was asked to respost here) Hi. I went through the firmware update on my Orbi setup. Router RBR20, main level two Satellites RBS20, one upstairs ...
DarkNet
Jan 14, 2021Apprentice
For what its worth, I have a RBR20 and two RBS20's like you. Here are my wireless settings which work for me.
dbadrak
Thanks for the response. It seems like you posted an image and it didn't like it.
What firmware do you have running on all your devices?
DarkNet wrote:For what its worth, I have a RBR20 and two RBS20's like you. Here are my wireless settings which work for me.
- DarkNetJan 14, 2021Apprentice
Same as yours. Latest update on the RBS20's and one behind on the RBR20 (I imagine I will update soon).
- dbadrakJan 24, 2021Aspirant
Here's an update.
I could not get the new 2.6.1.38 firmware to behave on my upstairs unit. I reset it to factory defaults (though not sure if it worked -- it did come back up on the network). Did the factory reset a couple times.
Ultimately dropped the firmware back to 2.3.5.36 (which is what I think I had before the updates). It would only drop it back to 2.5.1.16 (which is what the router RBR20 is).
Once this happened, it worked more reliably! The only odd thing is that the admin password is the default, and did not sync up with the router.
I'm hesitant to do anything more to it because we need strong wifi upstairs.
Don
- FURRYe38Jan 24, 2021Guru - Experienced User
I would keep v16 loaded on both units. Seems like more recent version of FW on the RBS is not working well with older version of FW thats on the RBR.
