RBK50_user1
Aug 15, 2019Follower
Issues with Orbi AC3000 losing internet connectivity with ATT Uverse(NVG589)
I have ATT uverse and am trying to run my Orbi AC3000 in router mode behind it and I periodically, at least 2-3 a day lose connectivity to the internet. The Orbi management page shows no errors in i...
ekhalil
Aug 15, 2019Master
This must be related to the ISP lease time issue that was introduced in recent Orbi updates and is still there in the latest 2.3.5.30.
A tested workaround that I currently have and has solved this issue for me to to reduce the lease renewal time in Orbi as follows:
* From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
* Enter admin as user name and your router’s management password
* Tick "Enable Telnet" option
* Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
* Enter the following commands:
* root@RBR50:/# config get wan_lease — Should give you --> 86400
* root@RBR50:/# config set wan_lease=720
* root@RBR50:/# config commit
