simondv
Jan 21, 2019Follower
Issues with ORbi connecting to ISP router after lights go out
Hi,
I have been having an issue with my Orbi. Everytime the eletricity goes down in the house my Orbi can't reconnect to the internet. The only way for it to work again is if I connect my PC to...
Jan 21, 2019Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
simondv wrote:
Hi,
I have been having an issue with my Orbi. Everytime the eletricity goes down in the house my Orbi can't reconnect to the internet. The only way for it to work again is if I connect my PC to my Bt HUB (ISP provider BT) via ethernet and then it works again. I don't have to do anything else apart from connecting via ethernet. Thanks in advance for the help
