simondv
Jan 21, 2019Follower
Issues with ORbi connecting to ISP router after lights go out
Hi,
I have been having an issue with my Orbi. Everytime the eletricity goes down in the house my Orbi can't reconnect to the internet. The only way for it to work again is if I connect my PC to...
Jan 28, 2019Guru - Experienced User
Any progress on this? Just checking...
simondv wrote:
Hi,
I have been having an issue with my Orbi. Everytime the eletricity goes down in the house my Orbi can't reconnect to the internet. The only way for it to work again is if I connect my PC to my Bt HUB (ISP provider BT) via ethernet and then it works again. I don't have to do anything else apart from connecting via ethernet. Thanks in advance for the help
