simondv
Jan 21, 2019Follower
Issues with ORbi connecting to ISP router after lights go out
Hi,
I have been having an issue with my Orbi. Everytime the eletricity goes down in the house my Orbi can't reconnect to the internet. The only way for it to work again is if I connect my PC to...
ekhalil
Jan 28, 2019Master
simondv wrote:
I have been having an issue with my Orbi. Everytime the eletricity goes down in the house my Orbi can't reconnect to the internet. The only way for it to work again is if I connect my PC to my Bt HUB (ISP provider BT) via ethernet and then it works again. I don't have to do anything else apart from connecting via ethernet. Thanks in advance for the help
- Is your ISP modem (BT hub) just a modem or does it have any router functionality? I'll assume here it's just a modem and Orbi is set in Router Mode.
- If this is the case, then the issue can be caused by either the lost connectivity with DNS or the ISP IP DHCP renewal is needed more frequently.
Let' try first with the first possible cause (the DNS). Please try using 8.8.8.8 as your primary DNS and see if the problem gets better.
DNS settings are found in the web GUI under >> ADVANCED >> Setup >> Internet Setup >>
