GrudgeMonkey
May 20, 2020Aspirant
Issues with printer wired to Orbi satellite
I have a Brother network printer connected by wire to my Orbi satellite. If I connect with my computer to WiFi while in the same room with that satellite, I can print. If I move to another room of the house, however, the print software tells me that the printer is offline. It's as if I've connected to another network, though I haven't. Is there some kind of firewall setting that I need to change, so data can go from one satellite to another?
GrudgeMonkey wrote:I have a Brother network printer connected by wire to my Orbi satellite. If I connect with my computer to WiFi while in the same room with that satellite, I can print. If I move to another room of the house, however, the print software tells me that the printer is offline. It's as if I've connected to another network, though I haven't. Is there some kind of firewall setting that I need to change, so data can go from one satellite to another?
There is no firewall setting on the Orbi controlling communication between devices except the choice of whether devices connected to the "Guest" WiFi can communicate with the primary network. Assuming this computer is connected to the primary Orbi network, then "no", Orbi has no internal firewall.
Does the printer have an IP address "assigned" to it? (On the Orbi Advanced Tab, Setup, LAN Setup? As printers tend to hang around for a long time, this is generally a good practice.
What sort of computer is trying to access this printer? (Mac, PC, Linux?)
- GrudgeMonkeyAspirant
I assigned the printer an IP address, but with a method different from what you suggested. In the Orbi setup, I left a range of IP addresses unmanaged, and on the printer setup, I assigned a static IP in that range.
I've tried printing from two devices. One is a Mac laptop, and the other is my Android smart phone. Both work when in the same room as the printer, and neither works from another room.
It is probably superstition on my part to avoid using "static IP's".
On the Orbi "Attached Devices" display, does it show the printer with the correct IP address?
Do you remember the other information used when setting up the printer static IP?
(subnet mask, gateway, dns?)
Thanks
