Gurgen
Nov 14, 2018Aspirant
Issues with some google services
We have purchased Netgear Orbi system with Setelite about 2 weeks ago. Everything works fine beside some of the google services.
For example:
We can's see the users icons in gmail built in ha...
Nov 14, 2018Guru - Experienced User
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What devices are you having problems with using Google?
Does this happen with all devices?
Gurgen
Nov 15, 2018Aspirant
Thanks for replay FURRYe38,
I don't see any firewall settings in my Orbi Admin panel.
Netgear Router is connected to wall LAN port with static IP, we don't have access to ISP modem and I don't know the device detals (it was working with the previous wifi access device).
Orbi system operates as a Router.
I having problems with google services with all device types including PCs, Laptops and Smatphones.
Thanks.
- FURRYe38Nov 15, 2018Guru - Experienced User
Try setting custom DNS on the Orbi router...1.1.1.1 and 9.9.9.9. Save settings and reboot the router and ALL devices...
