stephentyler20
May 31, 2018Aspirant
Issues with Zmodo wireless cameras
I finally got the Orbi RBK53 up and running. House as a Zmodo Camera System, which has 8 wired cameras (sPOE) and 4 wireless cameras (2.4 ghz Wifi). Here's the configuriation: - Ethernet -> RBR50 (in...
stephentyler20
That's a great point, although I did consider that and I've found it doesn't seem to matter. The cameras are connected to the nearest Orbi satellite or router, and since the cameras and Orbis are fixed, I figured they're probably not trying to change around a whole lot.
Interestingly, this problem didn't seem to be an issue when I had the Orbi in Router mode (rather than AP). I changed that on the recommendation of this forum, because my ATT modem/router does not have a bridge mode, so it was felt that it would be better to use the Orbi as an AP.
st_shaw
May 31, 2018Master
Not sure why AP mode would make a difference. I used to run wireless IP cameras on my Orbi in AP mode with no issues.
Consider that any time you lose power or reboot Orbi for any reason, the Router will come up first, and all your cameras will connect to the router, and never switch to the nearest Orbi device. So, unless you just checked the attached devices list, I would urge you to go back and make sure that all cameras are currently connected to the nearest Orbi.
- stephentyler20May 31, 2018Aspirant
OK thanks - I'll check again, but the other complicating factor is that one of the cameras is approximately halfway between the Orbi router and satellite. Another one is also fairly close to both. A third camera is far closer to one of the satellites than anything else, and yet it still doesn't connect well. So I will double check this, but I'm thinking it's not likely the solution.
Also - if that IS the issue, is there any way to force the connection to a given router / AP?
- st_shawMay 31, 2018Master
If your client devices do not roam, I don't know of a way to force them to a given AP.
In your case, the best solution might be to pull out your old WiFi router, run it in access point mode, set a different SSID, set a channel that doesn't conflict with Orbi, and use it only for your wireless cameras.
- stephentyler20May 31, 2018AspirantOk thanks. Yeah I considered that as well, but I run into the same problem that prompted my buying the orbi... The wifi doesn't reach throughout the whole house. So I'd have to install two access points. Which I guess I could do.
Frankly, I think I'm going to install some more hardwired cameras to replace the wireless ones. The wired ones always seem to work without difficulty, the wireless ones are just a headache to setup and keep functional.
