stephentyler20
May 31, 2018Aspirant
Issues with Zmodo wireless cameras
I finally got the Orbi RBK53 up and running. House as a Zmodo Camera System, which has 8 wired cameras (sPOE) and 4 wireless cameras (2.4 ghz Wifi). Here's the configuriation: - Ethernet -> RBR50 (in...
stephentyler20
Turns out this might be more camera-related than I thought. I noticed that one of the WiFi cameras was behaving perfectly normal - and it probably has the worst geographic / physical location of any of them. So I found a program from Zmodo (called ZBatch if anyone's interested) that lets you factory reset all the cameras. I downloaded that, did a factory reset, (which also reset the NVR, whoops), then unplugged all the Wifi cameras and reconfigured two of them, one at a time (just doing a trial with 2 for now).
Fingers crossed, but they seem to be working a lot better. Much more stable connection, and not choppy, as it was before.
I'm still going to put some more hardwired cameras in where I can, for good measure, but maybe (?) this has solved the problem for now.
st_shaw
May 31, 2018Master
Sounds good.
