rdawsoniii
Apr 10, 2018Star
I'VE JUST ABOUT HAD IT....
I've had the RBK40 for about 10 days and have yet to go 24 hours without problems. Constant disconnects. I've reset to factory default 3 times. I've updated to the newest firmware. Power cycled. ...
Little7
Apr 10, 2018Aspirant
I had the same issue when I started using my RBK40. I first shut down the satellite and then saw that the connection was OK from the router.
I then restarted the satellite and still the disconnects were observed (while watching a movie on the apple TV I saw the link being broken).
I was at that time running Firmware Version 2.0.0.56.
I just upgraded to Firmware Version 2.1.2.18 one week ago and so far so stable.
- rdawsoniiiApr 10, 2018Star
Same firmware with me. Neither version is stable, although with 2.1.2.18 the PC itself doesn't disconnect as often ("only" about 1-2 times per evening).
- Retired_MemberApr 10, 2018
based on what I've read in the community posts, many folks have problems with the AP modem. Not sure what to tell you other than perhaps get a different modem and let the Orbi router run as a straight router. Good luck.
