rdawsoniii
Apr 10, 2018Star
I'VE JUST ABOUT HAD IT....
I've had the RBK40 for about 10 days and have yet to go 24 hours without problems. Constant disconnects. I've reset to factory default 3 times. I've updated to the newest firmware. Power cycled. ...
rdawsoniii
Apr 10, 2018Star
Same firmware with me. Neither version is stable, although with 2.1.2.18 the PC itself doesn't disconnect as often ("only" about 1-2 times per evening).
Retired_Member
Apr 10, 2018based on what I've read in the community posts, many folks have problems with the AP modem. Not sure what to tell you other than perhaps get a different modem and let the Orbi router run as a straight router. Good luck.
- Retired_MemberApr 10, 2018
- rdawsoniiiApr 10, 2018Star
Retired_Member wrote:based on what I've read in the community posts, many folks have problems with the AP modem. Not sure what to tell you other than perhaps get a different modem and let the Orbi router run as a straight router. Good luck.
Thanks, but I am not buying a new modem. I can plug a "regular" router into my modem and it works right off the bat, with no issues. I should not have to be an IT tech to make the Orbi work. I'm glad others have no problems, but I do and am not happy.
I replaced my old router because it was getting old and did not cover my whole house.
If the above suggestions (other than buying a new modem, which is less than a year old) don't work tonight, the Orbi goes back tomorrow.
Sorry...I gave wrong info. Wireless is turned off on my modem, and the Orbi is NOT in AP mode.
so I have to ask....which device (your modem/router or the Orbi) is handling the router functions?
Retired_Member wrote:so I have to ask....which device (your modem/router or the Orbi) is handling the router functions?
The Orbi. Wireless is turned off on the modem. That is how I've always had it set up on my prior routers.
